Hello
I had 4.7.0-op24 installed on my Flint 2 router and it was working like a charm. I upgraded to 4.7.4-op24 and now the VPN will not start anymore no matter how many times I reboot the router or wait for it to connect.
I would like to avoid resetting the router to default values. I am using NordVPN's WireGuard directly in the router
Likely something breaks it and preventing for connecting, though you might need to reset to test it.
What i recommend is:
if you go to the advanced options login via luci, click on system -> and then backup and upgrade or something around these lines.
Then make a backup, extract this backup via 7zip and when you reset it you place back the wireguard config from /etc/config/wireguard from the backup, via winscp.
I don't think the vpn config is broken, but likely some sort of script.
Will try this once I get back home from work. Thanks for the suggestion. I already took a backup yesterday as this was the fastest option in case I have to revert back my settings.
