Perhaps look at what is already available for a relatively low price. Some serious consideration should be made to make the GL-iNet line more competitive in the hardware area.
This item is now available for about $80. The name has been blocked out.
RK3568B2 Soc, with 4GB LPDDR4x RAM and 32GB eMMC; CPU: Quad-core ARM Cortex-A55 CPU, up to 2.0GHz; [Dual PCIe 2.5G GBPS ETHERNET PORTS];M.2 WiFi and Bluetooth Module, with M.2 Key E;FriendlyWrt 22.03(64-bit), Debian Buster Desktop 64 bit;support 4KP60 H.265/H.264/VP9 video decoder, 1080P60 H.264/H.265 video encoder.
[WIRELESS MOBILE MINI TRAVEL ROUTER] Nnnnnnnnn Mini Wifi Router Adopt Rockchip RK3568B2 Soc, with 4GB LPDDR4x
 RAM and 32GB eMMC; CPU: Quad-core ARM Cortex-A55 CPU, up to 2.0GHz; GPU: Mali-G52 1-Core-2EE, supports OpenGL
 ES 1.1, 2.0, and 3.2, Vulkan 1.0 and 1.1, OpenCL 2.0 Full Profile; NPU: Support 0.8T.
[OPEN SOURCE and Programmable] It can support FriendlyWrt, a custom system based on the OpenWrt distribution. It
 is open source and ideal for developing IoT applications, NAS applications, smart home gateways, and more. It
 can also be used as a command line mode for geeks
[Dual PCIe 2.5G GBPS ETHERNET PORTS] The Nnnnnnnnn Mini Router has dual PCIe 2.5Gbps Ethernet ports; M.2
 WiFi(RTL8822CE) support 802.11 a/b/g/n/ac protocol,TX rate is 276Mbps,RX rate is 156Mbps.
[LARGER EXTENSIBILITY & Interface] Nnnnnnnnn Router supports M.2 WiFi and Bluetooth Module, with M.2 Key E:
 PCIe2.1 x1, USB 2.0 x1 Ports;microSD: support UHS-I; USB: two USB 3.2 Gen 1 Type-A ports; Debug: one Debug
 UART, 3 Pin 2.54mm header, 3.3V level ;1 x HDMI output interface; LEDs: 4 x GPIO Controlled LED (SYS, WAN, LAN,
 WL)
[OS/Software] Nnnnnnnnn Portable Router Running Android, FriendlyWrt 22.03(64-bit), Debian Buster Desktop
 (64-bit), FriendlyCore Focal Lite(Base on Ubuntu 20.04), Buildroot; Kernel version:
 Linux-5.10-LTS/U-boot-2017.09.
Guessing you are refering to the Nanopi R5C? It’s fair if you compare that against something like a Brume 2 (@ 69 USD), but that device will not do WiFi well.
Sticking in an Intel AX210 will not make it better than a Beryl AX as such wifi adaptor is not created to be Access Point. That adapter is made to be client. It would give you just 1 band wifi.
