i think “yes”. they are default GL.inet ar300 firmware version 2.13
yes, please refer to attachment
dmesg
root@GL-AR300:~# dmesg
[ 0.000000] Linux version 3.10.49 (alzhao@alzhao-ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r45620) ) #4 Wed Sep 23 10:53:49 HKT 2015
[ 0.000000] MyLoader: sysp=f38624f7, boardp=f68a8254, parts=29c0b996
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9344 rev 2
[ 0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x07ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 80338b60, node_mem_map 81000000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: board=GL-AR300 console=ttyS0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,16000k(firmware),64k(art)ro rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 126052k/131072k available (2386k kernel code, 5020k reserved, 620k data, 256k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.060000] Calibrating delay loop… 278.93 BogoMIPS (lpj=1394688)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.080000] MIPS: machine is GL AR300
[ 0.500000] bio: create slab <bio-0> at 0
[ 0.510000] Switching to clocksource MIPS
[ 0.510000] NET: Registered protocol family 2
[ 0.520000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.520000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.530000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.530000] TCP: reno registered
[ 0.540000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.540000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.550000] NET: Registered protocol family 1
[ 0.550000] PCI: CLS 0 bytes, default 32
[ 0.570000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.570000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.590000] msgmni has been set to 246
[ 0.590000] io scheduler noop registered
[ 0.590000] io scheduler deadline registered (default)
[ 0.600000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.630000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 0.640000] console [ttyS0] enabled, bootconsole disabled
[ 0.650000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.660000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.660000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.670000] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.680000] Creating 4 MTD partitions on “spi0.0”:
[ 0.680000] 0x000000000000-0x000000040000 : “u-boot”
[ 0.690000] 0x000000040000-0x000000050000 : “u-boot-env”
[ 0.690000] 0x000000050000-0x000000ff0000 : “firmware”
[ 0.710000] 2 uimage-fw partitions found on MTD device firmware
[ 0.720000] 0x000000050000-0x000000170000 : “kernel”
[ 0.730000] 0x000000170000-0x000000ff0000 : “rootfs”
[ 0.730000] mtd: device 4 (rootfs) set to be root filesystem
[ 0.740000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.740000] 0x000000660000-0x000000ff0000 : “rootfs_data”
[ 0.750000] 0x000000ff0000-0x000001000000 : “art”
[ 0.770000] libphy: ag71xx_mdio: probed
[ 1.330000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd042, driver=Generic PHY]
[ 1.340000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 1.890000] ag71xx-mdio.1: Found an AR934X built-in switch
[ 2.930000] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.930000] TCP: cubic registered
[ 2.940000] NET: Registered protocol family 17
[ 2.940000] Bridge firewalling registered
[ 2.950000] 8021q: 802.1Q VLAN Support v1.8
[ 2.960000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.970000] Freeing unused kernel memory: 256K (80350000 - 80390000)
[ 6.030000] usbcore: registered new interface driver usbfs
[ 6.040000] usbcore: registered new interface driver hub
[ 6.040000] usbcore: registered new device driver usb
[ 6.090000] SCSI subsystem initialized
[ 6.100000] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 6.100000] ehci-platform: EHCI generic platform driver
[ 6.110000] ehci-platform ehci-platform: EHCI Host Controller
[ 6.110000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 6.120000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 6.150000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 6.150000] hub 1-0:1.0: USB hub found
[ 6.160000] hub 1-0:1.0: 1 port detected
[ 6.160000] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 6.170000] uhci_hcd: USB Universal Host Controller Interface driver
[ 6.180000] usbcore: registered new interface driver usb-storage
[ 6.600000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 6.820000] hub 1-1:1.0: USB hub found
[ 6.820000] hub 1-1:1.0: 4 ports detected
[ 7.110000] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[ 7.560000] usb 1-1.2: new high-speed USB device number 4 using ehci-platform
[ 7.690000] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 7.690000] scsi0 : usb-storage 1-1.2:1.0
[ 7.800000] usb 1-1.4: new high-speed USB device number 5 using ehci-platform
[ 7.930000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 7.940000] scsi1 : usb-storage 1-1.4:1.0
[ 8.700000] scsi 0:0:0:0: Direct-Access JetFlash Transcend 16GB 1.00 PQ: 0 ANSI: 5
[ 8.710000] sd 0:0:0:0: [sda] 30867456 512-byte logical blocks: (15.8 GB/14.7 GiB)
[ 8.720000] sd 0:0:0:0: [sda] Write Protect is off
[ 8.720000] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 8.720000] sd 0:0:0:0: [sda] Write cache: disabled, read cache: disabled, doesn’t support DPO or FUA
[ 8.730000] sda: sda1
[ 8.740000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 8.940000] scsi 1:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
[ 8.950000] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ 9.870000] jffs2: notice: (378) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (1 unchecked, 19 orphan) and 87 of xref (0 dead, 67 orphan) found.
[ 14.900000] NET: Registered protocol family 10
[ 14.930000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 14.970000] nf_conntrack version 0.5.0 (1973 buckets, 7892 max)
[ 14.990000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.030000] Linux video capture interface: v2.00
[ 15.070000] u32 classifier
[ 15.070000] input device check on
[ 15.080000] Actions configured
[ 15.090000] Mirror/redirect action on
[ 15.110000] fuse init (API version 7.22)
[ 15.130000] usbcore: registered new interface driver cdc_acm
[ 15.140000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 15.150000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 15.150000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 15.170000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 15.250000] usbcore: registered new interface driver usbserial
[ 15.250000] usbcore: registered new interface driver usbserial_generic
[ 15.260000] usbserial: USB Serial support registered for generic
[ 15.290000] uvcvideo: Found UVC 1.00 device <unnamed> (046d:081b)
[ 15.320000] input: UVC Camera (046d:081b) as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
[ 15.340000] usbcore: registered new interface driver uvcvideo
[ 15.340000] USB Video Class driver (1.1.1)
[ 15.400000] xt_time: kernel timezone is -0000
[ 15.420000] usbcore: registered new interface driver cdc_ether
[ 15.480000] cfg80211: Calling CRDA to update world regulatory domain
[ 15.480000] cfg80211: World regulatory domain updated:
[ 15.490000] cfg80211: DFS Master region: unset
[ 15.490000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 15.500000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.510000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.520000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.530000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.540000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 15.550000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 15.550000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.560000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 15.570000] usbcore: registered new interface driver cp210x
[ 15.590000] usbserial: USB Serial support registered for cp210x
[ 15.610000] gspca_main: v2.14.0 registered
[ 15.610000] usbcore: registered new interface driver sonixb
[ 15.630000] usbcore: registered new interface driver sonixj
[ 15.650000] usbcore: registered new interface driver gspca_zc3xx
[ 15.720000] PPP generic driver version 2.4.2
[ 15.740000] NET: Registered protocol family 24
[ 15.750000] usbcore: registered new interface driver rndis_host
[ 15.830000] usbcore: registered new interface driver option
[ 15.850000] usbserial: USB Serial support registered for GSM modem (1-port)
[ 15.890000] usbcore: registered new interface driver rt2800usb
[ 15.920000] ath: EEPROM regdomain: 0x0
[ 15.920000] ath: EEPROM indicates default country code should be used
[ 15.920000] ath: doing EEPROM country->regdmn map search
[ 15.920000] ath: country maps to regdmn code: 0x3a
[ 15.920000] ath: Country alpha2 being used: US
[ 15.920000] ath: Regpair used: 0x3a
[ 15.950000] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 15.950000] cfg80211: Calling CRDA for country: US
[ 15.960000] cfg80211: Regulatory domain changed to country: US
[ 15.960000] cfg80211: DFS Master region: FCC
[ 15.970000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 15.980000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 15.980000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 15.990000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 16.000000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 16.010000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 16.020000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
[ 22.270000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 28.220000] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 28.220000] device eth1 entered promiscuous mode
[ 28.250000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 28.280000] IPv6: ADDRCONF(NETDEV_UP): eth1.1: link is not ready
[ 28.310000] IPv6: ADDRCONF(NETDEV_UP): eth1.10: link is not ready
[ 28.340000] IPv6: ADDRCONF(NETDEV_UP): eth1.2: link is not ready
[ 28.370000] IPv6: ADDRCONF(NETDEV_UP): eth1.3: link is not ready
[ 32.570000] IPv6: ADDRCONF(NETDEV_UP): wlan0-1: link is not ready
[ 32.580000] device wlan0-1 entered promiscuous mode
[ 34.610000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 36.880000] wlan0: authenticate with 04:18:d6:cd:77:ce
[ 36.890000] wlan0: send auth to 04:18:d6:cd:77:ce (try 1/3)
[ 36.900000] wlan0: authenticated
[ 36.920000] wlan0: associate with 04:18:d6:cd:77:ce (try 1/3)
[ 36.920000] wlan0: RX AssocResp from 04:18:d6:cd:77:ce (capab=0x431 status=0 aid=1)
[ 36.930000] wlan0: associated
[ 36.940000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 38.810000] br-lan: port 2(wlan0-1) entered forwarding state
[ 38.820000] br-lan: port 2(wlan0-1) entered forwarding state
[ 38.820000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
[ 38.850000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 40.820000] br-lan: port 2(wlan0-1) entered forwarding state
