WG obfuscation in Brume 2
Hello to all
I am trying to add obfuscation to the WG server. I hear that Shadowsocks, V2Ray and Amnezia are good choices. Does anybody have experience configuring those in GLNet routers?
You won’t be able to add obfuscation to the WG server provided by GL-iNet.
But you can install an additional Amnezia server. You need those two packages:
amneziawg-tools
kmod-amneziawg
But you have to configure everything manually in the CLI.
Never mind, as @Renato pointed out, you just need the 4.9.0 beta. I didn’t realize it’s already available.
Instal the 4.9 Beta: GL.iNet download center
Then: Set up VPN Obfuscation - GL.iNet Router Docs 4
Thanks Renato
The link mentions only special models: Brume 3, Flint 3, Flint 2, and Beryl AX
My router is Brume 2. Do you reckon it will work on it?
I guess so, because the release note is saying:
“…Added support for the AmneziaWG 2.0 obfuscation protocol...”
