I recently purchased, installed and configured a gl-ar750s-ext. Works great. I’m currently using it as an “access point”, which I configured via the web ui. I have a few follow on questions:
When I set the device “profile” as an access point, what does that actually do? Is “profile” the correct terminology? Does the change update some configuration files similar to using say
uci
? Or does it run a script under the covers? If it runs a script, what’s the script? I seem to be able to do something similar withluci
, so perhaps it’s just aluci
script. -
I changed the profile fairly early, before I really understood what I was doing. I then resorted to ssh-ing into the device and changing configuration files with
zile
and/oruci
. That’s fine, I learned bit along the way. If there’s a script to change router to access point, I’d like to augment it or create a second script. In my case, I changed the hostname, ssid’s, passwords, remove the guest ssid’s and installed some additional software (git, zile). I have a few of these devices, so I’d like to write a script and “do it once.” -
I’d like to install and configure a multicast dns service on the device. [OpenWrt Wiki] Multicast DNS Daemon seems to guide me, but the commands don’t work. I’d like to avoid
avahi
because it’s large and “not openwrt” (whatever that means, I just invented the term).
These devices are neat and (in my mind) present an alternative to purchasing repeaters or mesh wireless. They’re also useful to experiment with. Nice job. Thanks.
