What is causing this barrage of errors? its only going on when vpn is enabled on router cheers
flint ax1800
4.4.6
cheeera !
Fri Nov 3 22:52:47 2023 kern.warn kernel: [41944.051952] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:53:49 2023 kern.warn kernel: [42006.167719] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:53:49 2023 kern.warn kernel: [42006.168764] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:53:49 2023 kern.warn kernel: [42006.290854] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:53:50 2023 kern.warn kernel: [42006.923294] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:53:50 2023 kern.warn kernel: [42006.924349] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:53:50 2023 kern.warn kernel: [42007.128631] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:52 2023 kern.warn kernel: [42069.316820] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:52 2023 kern.warn kernel: [42069.317816] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:53 2023 kern.warn kernel: [42070.102948] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:53 2023 kern.warn kernel: [42070.104004] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:53 2023 kern.warn kernel: [42070.277257] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:53 2023 kern.warn kernel: [42070.278323] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:54 2023 kern.warn kernel: [42071.229376] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:54:54 2023 kern.warn kernel: [42071.230455] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:55 2023 kern.warn kernel: [42132.489696] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:55 2023 kern.warn kernel: [42132.494254] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:56 2023 kern.warn kernel: [42133.282554] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:56 2023 kern.warn kernel: [42133.283611] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:56 2023 kern.warn kernel: [42133.460792] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:56 2023 kern.warn kernel: [42133.461751] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:56 2023 kern.warn kernel: [42133.645986] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:57 2023 kern.warn kernel: [42134.306543] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:55:57 2023 kern.warn kernel: [42134.312693] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:58 2023 kern.warn kernel: [42195.642567] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:58 2023 kern.warn kernel: [42195.643519] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:59 2023 kern.warn kernel: [42196.463375] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:59 2023 kern.warn kernel: [42196.564626] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:59 2023 kern.warn kernel: [42196.565736] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:59 2023 kern.warn kernel: [42196.607567] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:56:59 2023 kern.warn kernel: [42196.608673] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:57:00 2023 kern.warn kernel: [42197.383702] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:57:00 2023 kern.warn kernel: [42197.384771] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
Fri Nov 3 22:57:00 2023 kern.warn kernel: [42197.588652] ath11k c000000.wifi: invalid pdev_id 2 in mgmt_rx_event
What kind of VPN do you use?
Good day to you, its Nord vpn
So open, i re did the config manually, its on currently as tcp ,
Any this error only happens when you enable NordVPN on the router?
