alexl
#1
I use GL-AR300M with 64Gb SanDisk Ultra USB pen drive and write video data there with about 20Mbits/sec rate.
The bad thing there is that the USB is reseted constantly with error like:
[ 3052.170000] usb 1-1.3: reset high-speed USB device number 5 using ehci-platform
I tried several pen drives and many OpenWrt configuration parameters with no luck.
So I am wondering if this issue can be overcame with GL-MT300A and MicroSD card?
What real application speed MicroSD can provide there (assuming I use strong class 10 card)?
And will the HW be able to write 20Mbits/sec constantly without issues like I have with USB?
Thank you in advance for your answers.
alzhao
#2
Can you try a differential power adapter? AR300M consumes more power.
MT300A can achieve 17Mbps when writing to SD card from our test.
alexl
#3
Thank you for your answers. I will try MT300A.
With AR300M I tried a few already up to 3A.
Also I tried a USB hub with additional power.
Is there any test/diagnostic I can perform to get more information on the USB issue?
alzhao
#4
Not sure. We can do some test here.
What file system format do you use? NTFS, ext, vfat?
alexl
#5
ext4 with the folowing mount options:
<span style=“font-family: ‘Helvetica Neue’, Roboto, Arial, sans-serif;”>rw,async,noatime,data=writeback,commit=300,barrier=1,min_batch_time=0,max_batch_time=0</span>
The case to reproduce is pretty straight forward:
4-6 processes that write data to the drive around 2-3 Mbps each. (actually all this data comes via ethernet)
The “reset” messages appears randomly each 10 min - 3 hours.
