Hi.
I’m very new to all of this, so I hope my explanation are clear enough and understandable.
I’m searching a very low power device to replace a “box” connected to a DSL line and act as router or switch and wifi access point. I’d also like to be able to connect an external directional antenna to that device too.
I would like the device to be connected to the actual “box” with RJ45 Ethernet cable sometime also.
The system I’d like is to share a DSL line with neighbour using their own box with a WIFI bridge to my place witch is about 150m. And sometime disconnect the box, and use my device to directly connect to the DSL line and provide WIFI bridge.
The device is meant to work on battery, so it needs to be low power at 5V or less to work on Lipo battery at ~3.5V.
Is there any product that could fit my needs at GLI ? I haven’t seen one with RJ11 connector.
