My AXT-1800 has the latest stable firmware 4.2.1 installed, however it’s really not stable to randomly reboot itself every couple hours. Fortunately it left a crash log to check of. Is there anyone who can roughly interpret what it is complaining about ?
Log Entry 6 (at position 5)
auth_rpcgss tun qca_ssdk vfat fat ntfs lockd sunrpc grace dns_resolver dm_mirror dm_region_hash dm_log dm_crypt dm_mod nls_utf8 nls_iso8859_1 nls_cp437 sha1_generic md5 des_generic cts mtdoops uas usb_storage gl_fan_driver xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom dbm uhci_hcd ohci_platform ohci_hcd phy_msm_ssusb_qmp phy_msm_qusb ehci_platform sd_mod scsi_mod ehci_hcd gpio_button_hotplug gl_sdk4_tertf usbcore nls_base usb_common mii gl_sdk4_hw_info
<4>[18345.583299] CPU: 1 PID: 132 Comm: kworker/1:2 Not tainted 4.4.60 #0
<4>[18345.583652] Hardware name: Generic DT based system
<4>[18345.589737] Workqueue: events rproc_crash_handler_work
<4>[18345.599701] task: 9d9e8d80 ti: 9d518000 task.ti: 9d518000
<4>[18345.599841] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[18345.605212] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[18345.611259] pc : [<7f914064>] lr : [<7f916764>] psr: 60000013
<4>[18345.611259] sp : 9d519e28 ip : 00000000 fp : 9d816428
<4>[18345.617866] r10: 8083a520 r9 : 9d816664 r8 : 00000000
<4>[18345.629052] r7 : 8075fde0 r6 : 9e5af610 r5 : 8075fde0 r4 : 9a86092c
<4>[18345.634261] r3 : 00000000 r2 : dc8ba63c r1 : 9eb4a324 r0 : 0000007c
<4>[18345.640861] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
<4>[18345.647371] Control: 10c0383d Table: 583a806a DAC: 00000055
<0>[18345.654574] Process kworker/1:2 (pid: 132, stack limit = 0x9d518210)
<0>[18345.660478] Stack: (0x9d519e28 to 0x9d51a000)
<0>[18345.666900] 9e20: 00000002 9a86192c 00000000 fffffffd 00000000 80044da0
<0>[18345.671161] 9e40: 8087d520 00000000 8075fde0 ffffffff 9d816428 80045094 00000000 9d519e6c
<0>[18345.679319] 9e60: 00000000 9d816778 9d816604 00000001 9d816400 800450c8 00000000 803572ec
<0>[18345.687480] 9e80: 9d81662c 8044c40c 9d81662c 9d816664 9d816400 9d81662c 9d8165c0 8044df58
<0>[18345.695640] 9ea0: 00000000 80357180 8073f63c 8075eeec 9d807480 00000000 9eb4a380 9d81662c
<0>[18345.703799] 9ec0: 9d816664 00000003 9d81662c 9d8165c0 9d816664 8083a520 9eb4cb40 8044e290
<0>[18345.711960] 9ee0: 8044e164 9d81662c 9de0be80 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[18345.720119] 9f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9de0be80 9de0be98 9eb4cb40
<0>[18345.728279] 9f20: 00000008 9eb4cb54 9d518000 8083a520 9eb4cb40 8003f1b0 80836100 9de0be80
<0>[18345.736438] 9f40: 8003eec8 00000000 9de0a780 9de0be80 8003eec8 00000000 00000000 00000000
<0>[18345.744598] 9f60: 00000000 8004428c 2234a222 00000000 a28e2b62 9de0be80 00000000 00000000
<0>[18345.752758] 9f80: 9d519f80 9d519f80 00000000 00000000 9d519f90 9d519f90 9d519fac 9de0a780
<0>[18345.760917] 9fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[18345.769077] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[18345.777237] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 8d2209a2 c4577038
<4>[18345.785524] [<7f914064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[18345.793563] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[18345.803804] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[18345.813356] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[18345.824117] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[18345.832882] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[18345.840958] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[18345.850678] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[18345.859964] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[18345.868036] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[18345.875152] Code: eb2550eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[18345.882361] ---[ end trace 3d2a23a2a280d1d5 ]---
<0>[18345.893028] Kernel panic - not syncing: Fatal exception
<2>[18345.893204] CPU3: stopping
<4>[18345.898148] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.60 #0
<4>[18345.900929] Hardware name: Generic DT based system
<4>[18345.908138] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[18345.912830] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[18345.920726] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[18345.927758] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[18345.935308] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[18345.942685] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[18345.950234] ff80: 00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[18345.955275] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 60000013 9e48ffd8
<4>[18345.963433] ffc0: 80019394 80019398 60000013 ffffffff
<4>[18345.971589] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[18345.976630] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[18345.984096] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[18345.992162] CPU0: stopping
<4>[18345.999014] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.60 #0
<4>[18346.001798] Hardware name: Generic DT based system
<4>[18346.009004] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[18346.013696] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[18346.021593] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[18346.028624] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[18346.036176] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[18346.043551] Exception stack(0x80835f50 to 0x80835f98)
<4>[18346.051101] 5f40: 00000001 00000000 00000000 8000b400
<4>[18346.056143] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[18346.064302] 5f80: 60000013 80835fa0 80019394 80019398 60000013 ffffffff
<4>[18346.072460] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[18346.078886] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[18346.086527] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[18346.094595] CPU2: stopping
<4>[18346.102834] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.60 #0
<4>[18346.105443] Hardware name: Generic DT based system
<4>[18346.112649] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[18346.117342] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[18346.125239] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[18346.132270] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[18346.139822] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[18346.147198] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[18346.154747] df80: 00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[18346.159788] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 9e48df80 9e48dfd8
<4>[18346.167947] dfc0: 80019394 80019398 60000013 ffffffff
<4>[18346.176102] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[18346.181143] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[18346.188609] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[18346.196682] The reading for sensor 4 is 0x002042e7
<0>[18346.203578] Couldn't get reading for sensor 5
<0>[18346.208391] The reading for sensor 7 is 0x002072e4
<0>[18346.212867] Couldn't get reading for sensor 8
<0>[18346.217506] The reading for sensor 13 is 0x0022d2ee
<0>[18346.221981] Couldn't get reading for sensor 14
<0>[18346.226621] The reading for sensor 15 is 0x0020f2eb
