The spec sheet says Qualcomm QCA9531. I did about two hours googling before I made a thread, but I still cant figure out which easytether driver I should use. Do Qualcomm chipsets get sorted under a different name?
I’ve already got easytether working on my PC from my phone (that’s how I’m posting this), and that works fine, without using the X750v2. However, when I take my Mint Mobile SIM card out of my phone, and put it in the X750v2, it works just fine with the default settings after a minute or two of automatic negotiation, however the pool it draws bandwidth from is the limited 5 Gigabyte hotspot pool, rather than from the unlimited plan I paid for. Do I need to set some packet TTL settings in the router itself? If so, what do I change, and what do I change it to? Thanks in advance.
