Hi I see the new firmwares below for my slate. please advice me about the one to use to update the firmware…
openwrt-ar750s-3.024-0604-IGMP
openwrt-ar750s-3.025-0617
openwrt-ar750s-3.025-0617-s2s
If you want to use site to site function , you need upgrade the firmware openwrt-ar750s-3.025-0617-s2s.
If you want to use IGMP , you need upgrade the firmware openwrt-ar750s-3.024-0604-IGMP.
The openwrt-ar750s-3.025-0617 is the standard firmware.
What’s that? I’m assuming it’s different from Repeater Mode?
Perhaps it’s an L2 tunnel?
I’m curious as well
Just use normal firmware openwrt-ar750s-3.025-0617
Other firmware will be explained later once they are ready to release.
