I am still facing issues with wifi on Flint AX1800.when I schedule wifi to be turned off more than half the times the wifi is not connecting afterwards and a restart is needed.
Also, randomly, the wifi connection will fail and also requires restart. While it is working fine it will loose connection.
Can you please investigate these 2 issues and hopefully fix them though the next firmware release?
Dear @luochongjun ,
Thank you for your reply. I am on 4.2.0 release 3 firmware. Did not update to 4.2.1 yet. Though this issue pre existed in version 3.x and 4.x.
Here is the log file (saved as zip I could upload): logread.zip (19.5 KB)
