I bought a used GL-MT1300. Not knowing what configuration has been installed, I wanted to immediately hard reset the device. Booting up I get a solid blue/gray light. Keeping the “reset” button pressed while booting the device gives me a solid white light. In either case I do not get the “GL-MT1300-cXX” wifi showing up on either my smartphone or Mac.
Maybe the reset button isn’t working on my router? Maybe the router itself isn’t working? I am unsure what’s going on here. I should also mention the original power supply was not included. Although I can’t imagine this to be the issue here.
Update: Trying to acess the admin panel through ethernet has not worked for my either. Windows 11 does not detect the ethernet connection when the Beryl is hooked up.
