Using an iPad or Android phone I can’t maintain a WiFi connection to the router. Both keep disconnecting and reconnecting when there is no internet connection via WiFi. Does anyone have suggestions as to how to maintain a stable connection to the router while configuring the repeater?
May I know what the router model and firmware version are?
- Could you please share the issue syslog with us?
- Does the repeater connection stable and the Internet available?
- How about the wired connection, is it stable?
Having exactly the same issue on my slate ax with an iPad Pro. The sta disconnects many times when there is no internet available and then the WiFi connection to the router dies. If I disable WiFi and enable it again, I’m unable to join the routers network again. A reboot temporarily fixes this until you try to connect to another station again.
Is your Slate AX connected to the primary router via repeater?
Are the primary WiFi multi APs (different BSSID, same SSID)?
What is the firmware version of Slate AX?
Please export the syslog and share it with us when the issue occurs.
