Previously I was using 3.203 (IIRC) and upgraded to 3.211. Since then, WiFi has become unreliable. It works for a few days, and then stops communicating with clients, and stops letting them authenticate.
I see a lot of AP-STA-DISCONNECTED
and IEEE 802.11: disassociated due to inactivity
messages in the logs at the end.
wifi down; wifi up
seems to bring it back.
My WiFi Config:
config wifi-device 'radio0'
option type 'mac80211'
option hwmode '11g'
option path 'platform/ahb/18100000.wmac'
option channel '6'
option txpower_max '23'
option txpower '23'
option noscan '0'
option htmode 'HT40'
option band '2G'
option disabled '0'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option wds '1'
option disassoc_low_ack '0'
option ifname 'wlan0'
option ssid 'REDACTED'
option key 'REDACTED'
option encryption 'sae-mixed'
config wifi-iface 'guest2g'
option network 'guest'
option mode 'ap'
option wds '1'
option ssid 'GL-XE300-8ec-Guest'
option encryption 'psk2'
option key 'goodlife'
option ifname 'wlan1'
option disabled '1'
option guest '1'
