Will VPN Policies work on mobile apps? For an example, if I don’t want to use VPN for youtube.com then will it work on the YouTube mobile app? Thanks.
VPN policy works with domain names. So if the app use the same domain name, then it should work.
What you need to do is the list all the domains that youtube.com uses.
