what are usable Win98 Keyboard and Mouse Settings?
I do not get the come to work on my Win98 retro build.
Kind Regards and Thanx in Advance!
Hi, does the keyboard and mouse not work when remote controlling?
Could you please try to change device identity or disable Virtual media to see if the problem can be solved?
Please also make sure your connection is correct. You can please refer the the link below to check.
Hi there,
Thanks for your reply!
The Comet works fine with modern computers, I just can’t get it to work with Win98. The Win98 works excellent with hardware usb mouse and keyboard.
What do I have to change the settings to?
I disabled the remote storage of the Comet, but this wasn’t helping either.
Kind regards!
Please Randomly change a device identity and disable the Virtuall media.
If still not work, I assume your Win98 cannot work with Comet. You can also export the log to us and we can try finding a solution.
