it is possible to make some buttons for windows, to command on/off for I/O ports?
or can you insert on web page control for GL-Inet ?
One way to do this, is to write a cgi using shell or lua, then call it from your windows applications or html.
But this is time consuming and need careful debugging.
You use CSS code.for making window button for I/O pin outs from downloaded Images.
