sopena
January 18, 2023, 3:48pm
#1
I have a OPNSENSE server Wireguard, and need a clients wireguard config in Mango.
The WG vpn in Mnago is accesing to the server OK, but i nned acces to Mango devices connecteds.
When ping to the local Lan (Opnsense) to Mango its not ping.
My config is:
192.168.5.x ( OPNSENSE)
10.10.10.x (WG )
192.168.8.x (Mango GliNET)
Is possible this config??
Do you have “Access Local Network” enabled on Mango? Is 192.168.8.0/24 added to AllowedIPs on OPNSENSE?
sopena
January 19, 2023, 1:09pm
#3
The option Acces local Netowrk on Mango is checked,
But the allowed IPS in Opnsesense in WG option??
You need to add 192.168.8.0/24 to the Allowed IPs configuration of the WireGuard Endpoint corresponding to the Mango
OPNsense → VPN → WireGuard → Endpoints
sopena
January 20, 2023, 12:40pm
#5
Yes i add the ip, and the same problem…
Can you run traceroute
command in your OPNsense?
traceroute 192.168.8.1
traceroute 192.168.8.x
192.168.8.x is your any client’s IP.
sopena
January 21, 2023, 12:18pm
#8
/usr/sbin/traceroute -w 2 -n -m ‘18’ -s ‘192.168.46.1’ ‘192.168.8.1’
traceroute to 192.168.8.1 (192.168.8.1) from 192.168.46.1, 18 hops max, 40 byte packets
1 192.168.8.1 30.137 ms 21.965 ms 38.008 ms
If put a ip 10.10.10.2 acess to Mnago config web.
wcs2228
January 22, 2023, 3:01am
#9
If you can reach devices on the Mango LAN from the OPNsense, but cannot reach the same devices from a client device connected to the OPNsense, then you may need to add a route on the OPNsense to go through WireGuard.
Are you hiding the intermediate nodes of traceroute
I may not have been clear, there are two most likely cases that could be causing this problem
OPNSense is not sending traffic to 192.168.8.x via VPN. This is a routing issue on OPNSense.
Requests from the VPN are being blocked by Mango and are not reaching the LAN. this is a firewall issue on Mango.
Please use traceroute
or check the route table on OPNSense to confirm if this is the case 1.
sopena
January 22, 2023, 7:54pm
#11
I create a route 192.168.8.x by WG Interface…
How to disable the router in Mango?
I don’t understand what you mean, are you trying to disable the firewall? You can check the forwarding settings of the firewall in the LuCI interface.
wcs2228
January 24, 2023, 2:30am
#13
What is the route that you created on OPNsense, including the Destination IP/Netmask, Gateway IP and Interface Name?
