I have a AR750S with Firmware 3.104.
I want to use Wireguard Client only to connect to my local home network and not for full internet access.
However this does not seem to work. As soon as I activate the wireguard client I loose access to the rest of the internet.
I thought the VPN policies would solve this problem but they don’t. Is there a known bug with the vpn policies?
With or without VPN policies activated it seems that starting the wireguard client sets the default route through the tunnel.
In the routing table I see the entries 0.0.0.0/1 and 128.0.0.0/1 set to wg0.
Is there a way to prevent the wireguard client from setting the default route through the tunnel?
(my allowed ips setting ist not 0.0.0.0/0 but only set to my internal network)
Yes wireguard works without setting policies, but then all traffic goes through the tunnel. Thats what I don’t want. I only want to route my private network at home trough the wireguard tunnel.
And that’s what I thought I could use VPN policies for.
But as I wrote in my previous post, the wireguard tunnel is always set as the default route, with or without the policies activated.
This is done in the wireguard start script.
But I don’t want the default route to change when activating wireguard or it needs to be reverted when setting the corresponding VPN policy.
