Wireguard Client (Beryl AX) unable to connect to Server (Flint)
Hi everyone!
I have a couple of routers working perfectly fine as Wireguard clients (Beryl and Mango) connected to my home server (Flint).
However, I receive an error when trying to connect through my new router, Beryl AX.
I tried the same configuration on my phone, and it’s working fine. However, when attempting to connect with my new Beryl AX, I receive the error below.
Could someone lend me a hand and let me know how I can solve this?
Thank you very much!
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): Warning: fw3_ipt_rule_append(): Can’t find match ‘connmark’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Zone ‘lan’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Zone ‘wan’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Zone ‘guest’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Zone ‘wgclient’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Set tcp_ecn to off
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Set tcp_syncookies to on
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Set tcp_window_scaling to on
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Running script ‘/etc/firewall.nat6’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Running script ‘/var/etc/gls2s.include’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): ! Skipping due to path error: No such file or directory
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): * Running script ‘/usr/bin/gl_block.sh’
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): Failed to parse json data: unexpected character
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): uci: Entry not found
Fri Mar 22 00:47:27 2024 daemon.notice netifd: wgclient (4124): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Fri Mar 22 00:47:27 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Fri Mar 22 00:47:27 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Fri Mar 22 00:47:27 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Any help from anyone please? thank you! :pray:
Unfortuntely wireguard logs are not very useful.
Two things to check:
  1. Does Beryl AX has Internet. Seems silly questions but let’s make sure.
  2. Beryl AX cannot connect to your Flint directly if you want the wireguard works. It has to be in another network.
Thanks a lot for your prompt reply!
Problem solved for the moment -the issue, I think, was that I was connected to the Flint network. Although I had already tried to connect through another network without success, it just started working now :slight_smile:
I will let you know in case of issues.
Thank you!
Oscar
