I was hoping to get some assistance. I have Flint 2 with Wireguard set up as server. I have Beryl Ax with Wireguard set up as client. The connection works perfectly. The issue is i have SSD connect to the USB on the flint 2 configured with a user profile. Mapped on my network, but when i use my beryl on vpn its says the folder cant be found and the name is incorrect. Any clue what might be the issue. The name are correct. TIA
Please verify if the PC which connected to Flint2 is able to "map to my network folder".
Please enable "Remote Access LAN" on the Flint2 VPN server, and restart Beryl AX and the Flint2 VPN.
