Hi, I recently got a GL-MT1300. I’m using it as a ‘VPN router’ at my house to my parent’s home. Basic setup. Change the wifi network names. Enable goodcloud. Setup the wireguard client. It worked great for about 2 weeks, and then it just stopped. The exact config, copy and pasted, works perfect on my Windows 10 Wireguard client and my iOS Wireguard client.
The “connect” button just eventually ends up saying “abort” and the dot to the left is orange. I’ve been using OpenWRT for years and when I ssh’d in I noticed that there wasn’t a wg0
interface. I tried reverting to stock and reconfiguring (SSID names, add 1 WG client profile, enable goodcloud, that’s all) but it still doesn’t work and there still isn’t a wg0
. I never supply a “listen port” but it seems the router auto generates one?
Any ideas how to get my Wireguard client working again? Seems like a lot of users have posted about this same exact problem without ever finding a resolution.
UPDATE: I noticed that the wg0
interface is created when I click “connect”. It still doesn’t work though. I added more diagnostic info.
I pasted some diagnostic info below:
ifconfig
before connect:
root@GL-MT1300:~# ifconfig
br-guest Link encap:Ethernet HWaddr 4E:4F:64:2C:D7:AA
inet addr:192.168.9.1 Bcast:192.168.9.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
br-lan Link encap:Ethernet HWaddr 94:83:C4:15:09:45
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:17336 errors:0 dropped:0 overruns:0 frame:0
TX packets:17737 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3330314 (3.1 MiB) TX bytes:15692067 (14.9 MiB)
eth0 Link encap:Ethernet HWaddr 94:83:C4:15:09:44
inet6 addr: fe80::9683:c4ff:fe15:944/64 Scope:Link
RX packets:22459 errors:0 dropped:0 overruns:0 frame:0
TX packets:11552 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:9589399 (9.1 MiB) TX bytes:2815334 (2.6 MiB)
Interrupt:23
eth0.1 Link encap:Ethernet HWaddr 94:83:C4:15:09:45
RX packets:1799 errors:0 dropped:0 overruns:0 frame:0
TX packets:2379 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:159266 (155.5 KiB) TX bytes:274752 (268.3 KiB)
eth0.2 Link encap:Ethernet HWaddr 94:83:C4:15:09:44
inet addr:192.168.1.198 Bcast:192.168.1.255 Mask:255.255.255.0
RX packets:18969 errors:0 dropped:91 overruns:0 frame:0
TX packets:8801 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8673715 (8.2 MiB) TX bytes:2253450 (2.1 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:82 errors:0 dropped:0 overruns:0 frame:0
TX packets:82 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8369 (8.1 KiB) TX bytes:8369 (8.1 KiB)
ra0 Link encap:Ethernet HWaddr 94:83:C4:15:09:47
Interrupt:25
rax0 Link encap:Ethernet HWaddr 94:83:C4:15:09:46
RX packets:18411 errors:0 dropped:0 overruns:0 frame:0
TX packets:20216 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4012582 (3.8 MiB) TX bytes:15876234 (15.1 MiB)
ifconfig
after connect
root@GL-MT1300:/etc/config# ifconfig
RX packets:59909 errors:0 dropped:0 overruns:0 frame:0
TX packets:60837 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:13383906 (12.7 MiB) TX bytes:80430455 (76.7 MiB)
RX packets:112341 errors:0 dropped:0 overruns:0 frame:0
TX packets:73297 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:96193115 (91.7 MiB) TX bytes:51434058 (49.0 MiB)
Interrupt:23
RX packets:7732 errors:0 dropped:0 overruns:0 frame:0
TX packets:8948 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:621546 (606.9 KiB) TX bytes:17873045 (17.0 MiB)
RX packets:63164 errors:0 dropped:198 overruns:0 frame:0
TX packets:37019 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:70909104 (67.6 MiB) TX bytes:10575629 (10.0 MiB)
RX packets:140 errors:0 dropped:0 overruns:0 frame:0
TX packets:140 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:14880 (14.5 KiB) TX bytes:14880 (14.5 KiB)
RX packets:7499 errors:1688 dropped:0 overruns:0 frame:0
TX packets:3387 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1558904 (1.4 MiB) TX bytes:1945859 (1.8 MiB)
Interrupt:25
RX packets:53889 errors:0 dropped:0 overruns:0 frame:0
TX packets:69384 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:13502569 (12.8 MiB) TX bytes:62211030 (59.3 MiB)
wg0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:192.168.99.2 P-t-P:192.168.99.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MTU:1420 Metric:1
TX packets:29 errors:0 dropped:3246 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:4292 (4.1 KiB)
wg
command output after connect - it is blank before connect
root@GL-MT1300:/etc/config# wg
interface: wg0
public key: t9ZtL...Xw=
private key: (hidden)
listening port: 64373
peer: OQt6o....ouHM=
endpoint: 98.155.123.123:51820
allowed ips: 0.0.0.0/0
transfer: 0 B received, 7.52 KiB sent
persistent keepalive: every 25 seconds
/etc/config/network/
root@GL-MT1300:/etc/config# cat network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdfb:99d3:73d0::/48'
config interface 'lan'
option type 'bridge'
option ifname 'eth0.1'
option ip6assign '60'
option hostname 'GL-MT1300-944'
option ipaddr '192.168.8.1'
config interface 'wan'
option ifname 'eth0.2'
option proto 'dhcp'
option ipv6 '0'
option metric '10'
config interface 'wan6'
option proto 'dhcpv6'
option disabled '1'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 1 2 3 6t'
config switch_vlan
option vlan '2'
option ports '4 6t'
config interface 'guest'
option ifname 'guest'
option ipaddr '192.168.9.1'
option bridge_empty '1'
config device 'wan_dev'
option name 'eth0.2'
option macaddr '94:83:c4:15:09:44'
config device 'lan_dev'
option name 'eth0.1'
option macaddr '94:83:c4:15:09:45'
/etc/config/wireguard/
root@GL-MT1300:/etc/config# cat wireguard
config proxy
option access 'DROP'
option main_server 'home'
option host '98.155.165.243'
option enable '0'
config peers 'wg_peer_299'
option name 'home'
option address '192.168.99.2/32'
option listen_port '64373'
option private_key 'EOmKm9...kyy91NovjYaRQ3jHc='
option dns '1.1.1.1'
option end_point 'mydomain.com:51820'
option public_key 'OQt6oI5peIv...pjR/pLsouHM='
option allowed_ips '0.0.0.0/0'
option persistent_keepalive '25'
