Wireguard connection turn to yellow sign
Wireguard connection turn to yellow sign and the connection is interruption. I found it happens in any models in Gl-inet. When the interruption of connection happened, I check the VPS servers are running well. another wireguard connection is also running well in the same time. Eventually, I have to change the new tunnel of the same server, then it will works.
when it happens, the green sing is changing to the yellow.
What do you mean?
Is this your own wireguard server?
yes, it is my own server. I created another tunnel from the same server and used it the Glinet. Then it works without yellow sign. However, it is from the server.
What is your router model? Can you upgrade to 4.x?
Do you use ddns in your wireguard config?
Can you post a sample config? You can mask the keys and sensitive info.
What is your router model? I have many routers of Glinet. It happed in every model, like AX1800, AXT1800, MV1000, MV1000w.
Can you upgrade to 4.x? It happed in 4.x and 3.x as well.
Do you use ddns in your wireguard config? No
