Hi, I’m using this guide to set up WG WireGuard - GL.iNet Docs on my B1300, I’m connecting with my Android official Wireguard app, leaving DNS blank would have DNS leak, setting it 10.0.0.1 is leaking as well. any idea what should be the correct DNS to set to let the router resolve DNS?
getting back to this, I’ve upgraded to v3, tested the Wireguard server, all works well.
However I’d like to ask how do I change the default DNS generated in the config file? I’d like to set it to 192.168.8.1 so that it will resolve DoT by cloudflafe in the router instead of 64.6.64.6 now.
sure I know that’s possible, but for me it’s better if I can change the default DNS to the router, that way sharing it with other people is easy without changing any configuration.
