WireGuard, Fritzbox 7590ax, E3372h-320, GL-MT3000
Hallo, I have a Fritzbox 7590ax with a WireGuard server. The VPN connection works perfect from abroad with my Android phone and Windows PC.
Now, I want my GL-MT3000, which is located abroad, to connect as a client to the Fritzbox 7590ax (192.168.2.1) in Germany. The GL-MT3000 (192.168.8.1) is either connected as a Wi-Fi repeater or (MultiWAN) via the Huawei E3372h-320 with the internet. I’ve been trying this for a week, but it’s not working. I’ve already experimented with many configurations, and I even had a connection once. My DynDNS is working well; do I need to open any ports, perhaps? Unfortunately, I’m not very tech-savvy.
MFG sandokanismo
After a long search I found the right config
[Interface]
Address = 192.168.8.1/24
ListenPort = 62687
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
DNS = 192.168.2.1, 192.168.8.1
MTU = 1420
[Peer]
AllowedIPs = 192.168.8.0/24, 0.0.0.0/0
Endpoint = XXXXXXXXXXXXX.myfritz.net:54254
PersistentKeepalive = 25
PublicKey = DWCiwpmIJzuMEmKSQ+9m7G0O4EZgVciiX8xjcrm7rTY=
PresharedKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hallo, I spoke too soon :face_exhaling:
The above config only works when the GL.iNet WireGuard client accesses the internet via Wi-Fi. As soon as I connect a USB Stick, I can no longer open any web pages. I have little knowledge, can someone PLEASE help me with what needs to be changed.
Fritz!Box7590ax: 192.168.2.1
Gl.iNet MT3000: 192.168.8.1 Fallback Multi-WAN 1) WiFi or 2) LTE
E3372h-320 HiLink: 192.168.10.1
LG sandokanismo
Can you disable wireguard and only use the LTE to access Internet? This is the first step.
