Flint GL-AX1800 WireGuard Server is failing to generate a user configuration with “ERROR Timeout”.
The router isn’t connected to the Internet, but I don’t see how that is required for generating a user config, am I wrong?
Running Firmware 3.214
The GL.iNet router at least needs to know the Public IP address for the Endpoint in the configuration file.
If that’s the case, is it possible to connect the GL-AX1800 to my current primary router LAN to LAN to get it online?
You should connect the GL-AX1800 WAN port to primary router LAN port. If you connect LAN-to-LAN, then you will get 2 DHCP servers from both routers on one LAN, which is not recommended.
Correct, but you can also disable the DHCP on LAN from within LuCI from what I’ve read.
