Wireguard Setup help
Good Morning,
I have a Beryl AX travel router. I use it as a repeater with a vpn on. I tried using Surfshark yesterday. I download the wireguard config on their website for the router then add the file to manual config. When I connect to surfshark it does not connect. Here is the log:
“Sat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Zone ‘lan’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Zone ‘wan’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Zone ‘guest’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Zone ‘wgclient’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Set tcp_ecn to off\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Set tcp_syncookies to on\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Set tcp_window_scaling to on\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Running script ‘/etc/firewall.nat6’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Running script ‘/etc/firewall.vpn_server_policy.sh’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Running script ‘/var/etc/gls2s.include’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): ! Skipping due to path error: No such file or directory\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): * Running script ‘/usr/bin/gl_block.sh’\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): Failed to parse json data: unexpected character\nSat Oct 21 10:03:21 2023 daemon.notice netifd: wgclient (21894): uci: Entry not found\nSat Oct 21 10:03:21 2023 user.notice mwan3[21893]: Execute ifdown event on interface wgclient (unknown)\nSat Oct 21 10:03:21 2023 daemon.notice netifd: Network device ‘wgclient’ link is down\nSat Oct 21 10:03:21 2023 daemon.notice netifd: Interface ‘wgclient’ is now down\nSat Oct 21 10:03:21 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nSat Oct 21 10:03:22 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()\n”
but with Mullvad it just connects seamlessly, here is the log for that:
“Sat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): * Set tcp_window_scaling to on\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): * Running script ‘/etc/firewall.nat6’\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): * Running script ‘/etc/firewall.vpn_server_policy.sh’\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): * Running script ‘/var/etc/gls2s.include’\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): ! Skipping due to path error: No such file or directory\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): * Running script ‘/usr/bin/gl_block.sh’\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): Failed to parse json data: unexpected character\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (23923): uci: Entry not found\nSat Oct 21 10:04:17 2023 daemon.notice netifd: Interface ‘wgclient’ is now down\nSat Oct 21 10:04:17 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nSat Oct 21 10:04:17 2023 daemon.notice netifd: wgclient (24014): RTNETLINK answers: Permission denied\nSat Oct 21 10:04:17 2023 user.notice mwan3[24013]: Execute ifdown event on interface wgclient (unknown)\nSat Oct 21 10:04:18 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()\nSat Oct 21 10:04:18 2023 daemon.notice netifd: Network device ‘wgclient’ link is up\nSat Oct 21 10:04:18 2023 daemon.notice netifd: Interface ‘wgclient’ is now up\nSat Oct 21 10:04:18 2023 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_1264 group_4231 group_7198 peer_2001 peer_2002 peer_2003 peer_2004 peer_2005 peer_2006 peer_2007 peer_2008 peer_2009 peer_2010 peer_2011 peer_2012 peer_2013 peer_2014 peer_2015 peer_2016 peer_2017 peer_2018 peer_2019 peer_2020 peer_2021 peer_2022 peer_2023 peer_2024 peer_2025 peer_2026 peer_2027 peer_2028 peer_2029 peer_2030 peer_2031 peer_2032 peer\nSat Oct 21 10:04:18 2023 user.notice mwan3[24674]: Execute ifup event on interface wgclient (wgclient)\nSat Oct 21 10:04:19 2023 user.notice mwan3[24674]: Starting tracker on interface wgclient (wgclient)\nSat Oct 21 10:04:21 2023 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)\n”
Can someone point me in the right direction on how I can resolve this please. I am connecting on a Public Wifi.
Thank you in advance.
I’m no good at reading logs… but perhaps it’s a config issues. Try a different Surfshark config for the location you are after and try again.
