Wireguard speed issue with Google TV (Beryl AX)
Hello Guys!
I am having wireguard speed issue with my Beryl AX, i get around 100-130mbps on my pc but when i use my Google Tv i hardly get 3-5mbps and sometimes on a good day i get 10-12mbps, could you please guide me how to solve this issue because i use wireguard for streaming on my google tv. thanks
Could you please let us know:
  1. The firmware version of Beryl AX.
  2. How do your PC and Google TV connect to Beryl AX? Via Wi-Fi 2.4GHz or 5GHz, wired?
  3. If your Google TV is connected via Wi-Fi 2.4GHz, please try to use 5GHz or wired to see if the VPN speed improves or not.
Hi Will,
  1. 4.8.2-op24
  2. Via WiFi 5Ghz
  3. Both my PC & Google Tv are connected to 5Ghz
I have a dedicate ip which i use for streaming via wireguard, i have no speed issues on my PC but Google Tv is giving me a big headache, i even reset the Beryl Ax to default and setup again and factory reset my Google Tv but issue remains the same. Thanks
Since your PC is working correctly, it seems the issue might be related to the Wi-Fi signal strength and speed at the location of the Google TV, or the Google TV its own Wi-Fi performance.
Could you please try running a speed test on your phone while standing right next to Google TV?
If your phone's speed is much faster, it would suggest that the issue is due to Google TV Wi-Fi.
If possible, would you be able to test a wired connection to see if that resolves the issue?
