I had my Spitz AX up and running on SIM 1. WireGuard was connected and my traffic routed through the WireGuard tunnel over the SIM 1 as expected. I then plugged an ethernet cable into the WAN port of the Spitz and into a port in a switch on my LAN. I ran a speed test and noticed that the results did not reflect my home ISP speed but did match the SIM 1 speed. I toggled the WireGuard client off and then back on. Same thing, traffic is being sent over SIM 1 and not the WAN port. With the WireGuard tunnel turned off the traffic does travel through my LAN and out through my ISP. Did a reboot and same behavior, when WireGuard is on the traffic is sent over the SIM 1 connection. Router is running 4.0-release50402.
I have tested this issue according to your description. We have a plan to optimize this issue in the next generation firmware. It will cost a long time. Please wait patiently.
mean while the support optimises this issue, you can add a static route to use ethernet wan
ip route add X.X.X.X/32 via Y.Y.Y.Y dev eth0
X.X.X.X is the wanguard server IP
Y.Y.Y.Y is the Ethernet gateway IP.
Where do I put this line? WireGuard config or somewhere else? And thank you for the temporary solution.
add the following on the cli of your router.
X.X.X.X is your wireguard IP.
can you also share route output on your router once.
