Wireguard-VPN does not work
Hi folks,
trying to establish a VPN-connection to a Wireguard-server with a GL-E750 which is connected to the internet via Wifi.
This is the log-result:
Sat Nov 15 21:50:52 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Nov 15 21:52:42 2025 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Nov 15 21:52:43 2025 daemon.notice netifd: wgclient (26751): REJECT  udp opt -- in br+ out *  0.0.0.0/0  -> 0.0.0.0/0   udp dpt:53 /* block_dns_manual */ reject-with icmp-port-unreachable
Sat Nov 15 21:52:43 2025 daemon.notice netifd: wgclient (26751): REJECT  tcp opt -- in br+ out *  0.0.0.0/0  -> 0.0.0.0/0   tcp dpt:53 /* block_dns_manual */ reject-with icmp-port-unreachable
Sat Nov 15 21:52:43 2025 daemon.notice netifd: wgclient (26751): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Sat Nov 15 21:52:43 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Nov 15 21:52:43 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Nov 15 21:52:48 2025 user.notice mwan3[26779]: Execute ifdown event on interface wgclient (unknown)
Sat Nov 15 21:52:54 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sat Nov 15 21:54:36 2025 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Nov 15 21:54:37 2025 daemon.notice netifd: wgclient (29582): REJECT  udp opt -- in br+ out *  0.0.0.0/0  -> 0.0.0.0/0   udp dpt:53 /* block_dns_manual */ reject-with icmp-port-unreachable
Sat Nov 15 21:54:37 2025 daemon.notice netifd: wgclient (29582): REJECT  tcp opt -- in br+ out *  0.0.0.0/0  -> 0.0.0.0/0   tcp dpt:53 /* block_dns_manual */ reject-with icmp-port-unreachable
Sat Nov 15 21:54:37 2025 daemon.notice netifd: wgclient (29582): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Sat Nov 15 21:54:37 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Nov 15 21:54:37 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Nov 15 21:54:44 2025 user.notice mwan3[29609]: Execute ifdown event on interface wgclient (unknown)
Sat Nov 15 21:54:48 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Any ideas why it does not work?
Thank ahead!
It seems that it cannot connect to the server.
When you import the same VPN profile on your pc, can the pc connect to the VPN server and does the Internet work fine?
