Wireguard VPN not working on Latest Firmware
I recently purchased a GL-MT3000/Beryl AX and what a great little box!! It’s working fine with ProtonVPN’s OpenVPN Client config, but the WireGuard client config has never worked. I’ve tried every config option possible from Proton’s site, but everything fails. I’ve attached a sample of the log file below that contains the errors, which are the same no matter which options I try. It would appear that there’s a problem in the software itself, not the ProtonVPN Wireguard Config. I even reset the router to factor settings and set up a config using the "Item Mode’ on the MT3000, but the results were all the same.
Kernel Version: 5.4.211
Firmware Version: 4.4.6
Please help!! I live in a country with ever tightening interest restrictions and VPN is my crucial lifeline. Thanks so much in advance.
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Rule ‘lan_in_conn_mark_restore’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Rule ‘out_conn_mark_restore’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Zone ‘lan’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Zone ‘wan’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Zone ‘guest’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Zone ‘wgclient’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Set tcp_ecn to off
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Set tcp_syncookies to on
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Set tcp_window_scaling to on
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Running script ‘/etc/firewall.nat6’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Fri Oct 27 20:58:41 2023 daemon.notice netifd: wgclient (12975): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Fri Oct 27 20:58:42 2023 daemon.notice netifd: wgclient (12975): * Running script ‘/var/etc/gls2s.include’
Fri Oct 27 20:58:42 2023 daemon.notice netifd: wgclient (12975): ! Skipping due to path error: No such file or directory
Fri Oct 27 20:58:42 2023 daemon.notice netifd: wgclient (12975): * Running script ‘/usr/bin/gl_block.sh’
Fri Oct 27 20:58:42 2023 daemon.notice netifd: wgclient (12975): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Fri Oct 27 20:58:42 2023 daemon.notice netifd: Interface ‘wgclient’ is now down
Fri Oct 27 20:58:42 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Fri Oct 27 20:58:42 2023 user.notice mwan3[13073]: Execute ifdown event on interface wgclient (unknown)
Fri Oct 27 20:58:42 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
It must be some firewall between MT3000 and Proton VPN server blocking the traffic.
Some users reported Netgear xr500 gateway is not working well with our wireguard client.
But try to set a lower MTU, and remove the listen port if there’s one.
