Hello? I will close this I just need this one question above answered. Thanks for all of your time and support!
- After you set up openvpn, you should be able to access each node using the vpn IP address, e.g. 10.10.0.x
- Then you set up port forward in each router. From vpn zone to the client IP. Example like below
Perfect! Thank you so much since this is a remote install I will have to wait to try it out so I will just close this in the meantime.
Again I thank you for all of your work and support and I have to say your router remotely is working very well!
