The wireless page not showing on the upgrade on GL-MT6000.
I tried downgrading the firmware to 4.6.4 and 4.6.2 but same issue.
My current version is
Version : 4.6.8
Firmware Type : release1
Version : 4.6.8
What about gl-inet app on your mobile? Can see WiFi on your mobile?
Try full reset factory or something in luci can configure WiFi
Try to run via SSH
uci set wireless.default_radio0.ifname='wlan1'
uci set wireless.default_radio1.ifname='wlan0'
uci set wireless.guest5g.ifname='wlan1-1'
uci set wireless.guest2g.ifname='wlan0-1'
uci commit wireless
reboot
If this does not help, you need to reset your unit to factory settings.
I have contacted support and found the solution. (user fault)
After analysis, it is determined that the problem is present in the configuration of the LAN.
The IP address of the page LAN here is not configurable in this format
As a result, an exception error is reported, and the wireless content will be lost on the web interface
