WISP CIFS problem
I have setup an GL-AR300M successfully as WISP repeater.
Everything works except for CIFS. Under Windows 10 I can’t get my drive mappings to work.
I suspect an issue with UDP broadcasts, so can CIFS work in WISP mode or only WDS ?
If the main AP doesn’t support WDS what then ?
Because your router behave like a firewall so network shares doesn’t work in WISP mode.
It only works in WDS mode.
If the main router doesn’t support WDS, try relayd, as docs here:
http://www.gl-inet.com/docs/mini/internet/#repeater-bridge-relayd
