I have a GL-AR750 running in WISP mode, connecting to the WiFi network of a hotel I am staying at. I currently see 18 devices listed in the configuration interface (only 2 of them are mine!), listed as DHCP leases. Screenshot attached.
Not entirely sure what is going on and a bit concerned that I am seeing all these random devices as “DHCP Clients”. Can you explain what this is, shouldn’t this device be isolated from the upstream network?
I have tried restricting the listen interface to be LAN only in Luci but that didn’t change anything, I still see rogue devices. Screenshot also attached.
I used to have the AR750 working fine, but I found some hotel which registration portal cannot be reached behind the AR.
And I can see it with Marriott for instance, hotel you mentioned.
Can you please share how you do it in this case ?
I’m wondering if there is way to install get access to a we browser running on the GL, so I can do the registration from it.
