When I try to copy a file between the 2 mac, if I am very close to the router with both I have a writing speed of 8 Mbps and a reading speed of 30-40.
Both mac have an SSD, the WI-FI is on 150 Mbps (I tried with 300 but I did not notice a change), channel 11 and power 20.
Is this speed normal ? In the future I would like to connect a NAS to the router, I am a bit worried…
Moreover, when I am using a VPN my download speed is around 14 Mbps (with a 50 cm ethernet cable cat7 directly connected to the ISP’s modem) it is very very good for a router like that but I expected 15-16 and without the VPN my download speed is around 70 Mbps (If I am directly connected to the ISP’s modem/router without the AR300M my speed is 145 Mbps).
Do you think that I have a problem in my settings ?
The mini router is 100Mbps so 70Mbps on wifi is good enough.
But I am not sure about the mac writing speed. You may test the wifi speed for each mac when connected to the mini router and check if both connection is good.
