Best device for remote work .
Can you suggest The best device for working remotely without being detected thanks
I suggest COMET POE , reasonable price. newest chip. and good looking.
And you need to perform some disguising configurations on it with your own computer before connecting it to the company's computer.
I use my personal computer for work. If there are other devices, such as a router or similar, that are easier and safer, please suggest them. Thank you.
"Without detection" is the big red flag. Everything can be detected if you're competent enough, best bet is to ask IT what is and isn't allowed.
bro I was using the RM1. But they havent released the patched version with webcam passthrough. Just waiting for that for it to be a complete machine
