Working remotely when traveling
Can I work remotely using this device, knowing that the company I work for uses its own VPN?
Yes. Many people are using it for this.
You’ll set up you own vpn on the routeur and still use your company vpn on your laptop.
Yes, it is possible, but occasionally some users report the network speed may be very slow in the scenario of VPN tunnel over tunnel.
Ok, in my case my company is using IPSec and I'm using wireguard and it’s working well.
