Working solution for eSIM management on Slate 7 + RM520N-GL via USB
Previously I’ve asked about eSIM management solution in this topic. Today I’ve got working solution.
It uses native UI for eSIM management (from official package), but replaces missing backend part with AT commands.
Caution: it requires SSH root access to your router and make a small modification to original firmware. Use at your own risk.
Thanks for sharing this solution and your experience with the community.
It is great to know that this approach works with the Slate 7 and an external RM520N-GL setup, and it may be a helpful reference for other users with similar requirements.
As you mentioned, this solution involves root access and modifications to the original firmware, so users who would like to try it should keep this in mind.
Thanks again for taking the time to share such a solution!
