Wyze Cam can’t connect via 750M router
I have a 750M that works great. It can connect to the internet via other routers and other devices can connect to it and get internet access that way.
I have a Wyze Cam that I can use on lots of other routers. I cannot get the Wyze to set up on the 750M. Wyze support says they think there is some sort of “Client Isolation” enabled on the 750M, but I cannot find anything like that in settings or advanced settings.
Any suggestions?
Client isolation is disabled by default.
You might need to enable IGMP. Please try to ssh to the router and do as follow.
**Update package**
# opkg update
# opkg install kmod-bridge
**Enable IGMP**
# uci set network.lan.igmp_snooping=1
# uci commit network
# echo "1" > /sys/devices/virtual/net/br-lan/bridge/multicast_snooping
**Reboot**
# reboot
