Wyze Cam v3 disconnecting and reconnecting to Flint 3
My only Wyze v3 camera is constantly losing connection to the Flint 3 2.4 wifi. Wifi has a unique SSID since I only use 2.4 for IOT and cameras.
Seeing this in the log. Running the latest stable release FW. Any ideas?
Tue Feb 17 10:00:54 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: authenticated
Tue Feb 17 10:00:54 2026 kern.err kernel: [111627.355546] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :d0:3f:27:0a:1a:91
Tue Feb 17 10:00:55 2026 kern.err kernel: [111627.848081] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :d0:3f:27:0a:1a:91
Tue Feb 17 10:00:55 2026 kern.err kernel: [111628.350280] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :d0:3f:27:0a:1a:91
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: associated (aid 6)
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 WPA: sending 1/4 msg of 4-Way Handshake
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 WPA: sending 3/4 msg of 4-Way Handshake
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 RADIUS: starting accounting session 43DAB9057445DABD
Tue Feb 17 10:00:55 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 WPA: pairwise key handshake completed (RSN)
Tue Feb 17 10:00:55 2026 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.8.101 d0:3f:27:0a:1a:91
Tue Feb 17 10:00:55 2026 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.8.101 d0:3f:27:0a:1a:91
Tue Feb 17 10:00:56 2026 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.8.101 d0:3f:27:0a:1a:91
Tue Feb 17 10:00:56 2026 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.8.101 d0:3f:27:0a:1a:91
Tue Feb 17 10:00:57 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.101 d0:3f:27:0a:1a:91
Tue Feb 17 10:00:57 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.101 d0:3f:27:0a:1a:91 WYZE_CAKP2JFUS-D03F270A1A91
Tue Feb 17 10:09:47 2026 kern.err kernel: [112160.050478] wlan: [0:I:ANY] [INACT] vap-0(wlan0): [d0:3f:27:0a:1a:91]station kicked out due to excessive retries associd 6 (from target) reason 1
Tue Feb 17 10:09:47 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:09:53 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:03 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:08 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:09 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:10 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:13 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:14 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
Tue Feb 17 10:10:15 2026 daemon.info hostapd: wlan0: STA d0:3f:27:0a:1a:91 IEEE 802.11: disassociated
I too am seeing these errors about 3 times a minute on the Flint 3 w/4.8.4 FW on a 2.4GHz connection. The only difference being the device is an EcoFlow River 3.
Wed Feb 18 15:56:45 2026 kern.err kernel: [ 1744.842446] wlan: [0:I:ANY] [INACT] vap-0(wlan0): [f0:f5:bd:30:6c:d0]station kicked out due to excessive retries associd 4 (from target) reason 1
I would like to know if this is something I need to be worried about.
Bueller? Bueller?
Jut come back from the from the Chinese New Year holiday.
Please check the following:
  1. Make sure the SSID is set to WPA2-only encryption, as some IoT devices have poor compatibility with WPA3.
  2. Try setting the 2.4 GHz Wi-Fi mode to 802.11n/g, since some IoT devices may not work well with ax/be modes.
uci set wireless.wifi0.hwmode='11ng'
uci commit wireless
/etc/init.d/network restart
  1. Try disabling 802.11v on the corresponding SSID, as the log indicates that the issue appears to be related to roaming.
# On Main SSID
uci set wireless.wifi2g.bss_transition='0'
# On Guest SSID
uci set wireless.guest2g.bss_transition='0'
uci commit wireless
Kung Hei Fat Choy.
I’m happy to report that after going with Option #2 I am no longer seeing the “station kicked out” errors on my EcoFlow River 3.
I went with Option #2 because it also happened to fix Flint 3 2.4 Ghz instability (kernel errors) for me. Thank you! @will.qiu
Thanks. I’ll try it later, but I have purchased a 2.4Ghz standalone AP to try to offload some of the 40-ish IOT items I have and that particular camera to seems to be working great with it.
