+QCAINFO: “PCC”,1802,100,“LTE BAND 3”,1,250,-69,-15,-34,10
+QCAINFO: “SCC”,375,75,“LTE BAND 1”,1,250,-73,-7,-56,14,0,-,-
+QCAINFO: “SCC”,723322,12,“NR5G BAND 79”,251
Yeah, I tried to modify the MTU using another SIM. At the moment I am testing with another operator that doesn’t require MTU adjustment. I’ll try againg when you’ll add the feature on the modem setting
The issue with failover appears to be not just when VPN is active. I have Ethernet and cellular connected. With VPN off, and cellular set to failover priority 1, data always uses Ethernet even after reboot. Turn on VPN and data always uses cellular, even with Ethernet failover priority set to 1. Multi wan failover is totally useless until this gets fixed. Mwan3 tab in luci shows the correct priority setting but it is not being honored.
Surfshark wireguard not changing location successfully without disabling VPN first. I shouldn’t have to disable the VPN in order to change the location. This is using the app. I will try through the web browser and see if the behavior is the same.
