GL-X3000 Spitz AX, 4.9.11b EIOT eSIM
I had tested this firmware from home and it seemed to work fine, but when I was traveling this past week, I couldn't connect to any cell service until I reverted to the 4.8.4 firmware. A tower scan indicated several strong AT&T and T-Mobile signals.
I've sent the cell and router diag logs to support.
Thanks for your report.
We noticed that you have already reached out to us by email regarding this issue.
Please continue working with our support team through the ticket system so we can assist you more effectively.
This post will remain open in case other users wish to share additional suggestions.
I worked with @Cathy and we discovered the problem.
I had locked my router to 5G and when you do that, it will only connect to SA (not NSA) signals. I was able to validate this from home (we weren't at the hotel by the time Cathy responded) and also learned that the EIOT eSIM can't connect to SA signals (one more strike against it because it also doesn't support IPv6).
I'm on the search for a replacement eSIM provider that does support SA (and hopefully, IPv6), but the results so far are disappointing.
