X3000 switching to SIM 2 upon restart
I've been running into a similar problem on my X3000. Two sims installed, different telco's. Upon boot everything connects as it should. When sim1 is configured then it connects to sim1 at boot, when sim2 is configured it connects to sim2. But only at boot.
When manually switching (auto switch disabled) between sims, more often than not, the connection cannot be established. Cell details are populated but the sim remains unregistered. Only after rebooting it will actually connect succesfully.
Sorry, I couldn't find your device. Please share your device through the following steps:
Technical support via GoodCloud - GL.iNet Router Docs 4
I am experiencing the same issue with my X3000. I am using a T-Mobile SIM, and spoof the IMEI of another device. I have no SIM in slot 2.
If I manually switch the SIM back to SIM 1 via the GUI, service is restored.
My firmware is current.
hi @Synchros
We have optimized it and you can verify its effectiveness in the 4.8.0 beta version
