X300b swap 4g modules?
Just wanted to know if it is possible to change the module in the x300B? If so are there any requirements for the other module? (support linux, size, etc?)
Thanks!
Yes you can.
For size, if you use PCIe modules the size should be same.
Yes you need Linux driver that could be an issue. You can use Quectel EC20, EC25, EP06, EG25.
May also try Sierra MC7455 PCIe.
But for other models you may need to add drivers.
I appreciate the reply!
Thank you.
@alzhao do you know if a cheaper mc7355 would work?
Sorry no idea about this modem
