I tried to flash the std OpenWRT 23.05 release onto my x750 and now it doesn't even boot. When I power on only the internet LED is on and never blinks, reset button pressed or not.
I hooked up serial and this is what I see:
You flashed the plain OpenWrt image, I assume? Not the sysupgrade one?
In that case, you might need to go through this here: [OpenWrt Wiki] Installing OpenWrt
Depending on what the flashing process did, you might be not able to get back to GL firmware without further help from the support team.
I flashed the sysupgrade image
I cannot follow the instructions you linked to, the device doesn't progress past what is shown in my screenshot above.
I'm wondering whether I need to reflash uBoot to the SPI flash chip?
Edit: can I download the u-boot image for this device anywhere?
