Hello. I’ve received XE300 Puli with the firmware “4.3.28 alpha1”. It worked perfectly, but I was experiencing some issues with LTE (speed 20 mb/s max - but later I’ve found that its ok for mmy LAN module).
But I didn’t like its “alpha1” and upgraded to 4.3.27 (in fact, downgraded). After it, I found out:
- LAN speed dropped from 75 to 40 mb/s
- LTE speed dropped from 20 to 12-16
- Luci is installed and cannot be removed, while I don’t need it, and it occupies memory
- Less settings for LTE available (i.e. no way to change IMEI)
4.3.28 alpha1 is not available on the firmware website: GL.iNet download center
Is there any way to get it, or any other firmware which will not have issues which I noticed for 4.3.27? (I even tried 4.8.3 beta, but it is even worser)
