XE3000 Puli AX Dual Sim Question
Good afternoon
If you know how, can you help me configure my Puli AX sims?
I know this item only has Modem but has 2 sim slots, I have both of the sims populated, I want the Puli to automatically switch between the two sims once a day at some time ,like 3 am.
The idea is to balance the data use between the two sims.
If this is not possible, I’d like to request it in the next firmware upgrade.
thank you
Rico
pls upgrade to the latest beta and refer to this link
The auto switch only goes one way. To the preferred sim card. Once there It can’t go back to the 2nd sim unless there is not data on the preferred sim.
Any suggestions?
Rico
