Xray for SFT1200
I’m looking for the xray-core package for the SFT1200 (Opal) for my travel to China.
There are official OpenWRT packages compiled for it but i don’t know if it’s exactly the same architecture, e.g xray.
Which one could it be between mipsel_24kc, mipsel_24kc_24kf, mipsel_74kc and mipsel_mips32?
Ssh into your modem then execute:
opkg update
opkg install file
Then to find the arch of your system run the file command against any binary in /bin/ or /usr/sbin/
But mipsel seems to be wrong, it should be arm.
Unfortunately it’s not in https://fw.gl-inet.com/releases/v18.06.5/packages-3.6/siflower/packages/ which is the only available repository I have for now
Doing cat /proc/cpuinfo I obtain system type: MIPS sf19a28 with isa: mips1 mips2 mips32r1 mips32r2 and cpu model: MIPS interAptiv
Ah, ok :slight_smile:
Thought it’s ARM. But good to know!
